Wardsweb
Renaissance man
I recently picked up this amp from a friend and intend to use it in my home theater. Before I do that, I did some testing with a pair of JBL 4311B speakers. This thing is so over the top, the LED VU meters don't move at normal levels. If I turn it up, I get a second LED to light. In my home theater with higher efficiency speakers, the amp will be idling.
Basics:
What is the weight?
94 lbs (net); 107 lbs (boxed)
What are the dimensions?
17" wide x 9.5" high x 19.5" deep
What is the rated power?
400 watts / channel (x5); all channels driven; into 8 Ohms.
600 watts / channel (x5); all channels driven; into 4 Ohms.
500 watts / channel (x2); two channels driven; into 8 Ohms.
750 watts / channel (x2); two channels driven; into 4 Ohms.
575 watts / channel (x1); one channel driven; into 8 Ohms.
1100 watts (1 .1 kW) / channel (x1); one channel driven; into 4 Ohms.
Basics:
What is the weight?
